Here is the contents of my previous unanswered post:
Okay, you got me. I am a newbie. I was trying to follow the "DVD backup without having 8GB free" document by Dhruv Bhatia.
Downloaded and installed TMPGEnc, VFAPI plug-in, and DVDx.
Set up DVDx output settings as Video Server (it has Video Server twice under the selections "Premiere Plugin Encoder" box. Does that mean I may have more than one plugin installed - causing problems?). Under Video Server Settings, I am using "connect to AVISynth" and gave the .avs filename. Click on encode.
After this, I open TMPGEnc and set the .avs file as the video source and give the .mpg output file name. Load a VCD template and click start.
I get the following error:
Script Error: There is no function named "IPCSource"
(C:\temp\majestic_2\The_majestic.avs,line1)
Please help me out in simple terms - I'm stupid......
I would appreciate it if ANYONE could help me out or tell me of a better way to do it.
Also, FYI, i opened the "the_majestic.avs" file in a txt editor and it contained the following text:
IPCSource("the majestic.mpg")
resampleaudio(44100)
Please help me out!
Results 1 to 1 of 1
was rumored to have been said by Twezel
what would the best setting for me for Handbrake ? plz answer
By FaisalKhan in forum Newbie / General discussionsReplies: 3Last Post: 4th Jan 2011, 09:38 -
SURELY something this simple exists... But apparently not! CD to MP3
By KuriousJorj in forum AudioReplies: 4Last Post: 11th Oct 2009, 04:27 -
PLASMA resolution..1024x1080 (or 1024x768) ..surely isnt widescreen?
By snadge in forum DVB / IPTVReplies: 6Last Post: 2nd Sep 2007, 12:24 -
Hard question that nobody can answer: Why LCD > CRT?
By SignedupGuest in forum Newbie / General discussionsReplies: 31Last Post: 20th Jul 2007, 12:34 -
Need someone who has seen Transformers The Movie(animated) to answer Q?
By Denvers Dawgs in forum Off topicReplies: 10Last Post: 27th Jun 2007, 21:42
