Hi Guys
Yet another sound problem(Just my luck)
I've downloaded a movie this time Exit Wounds plays fine on mi pc, but when converted the sounds out of sync & gets worse as the film goes on. Ive tried twice but with no joy.
Hope ya can help
Thanx.....
Well if you scanned the movie for bad frames and found none, then I guess its not that. Your only option is to save out the sound uncompressed, then you can use this later with TMPGEnc to make the mpeg1
Vidub
Video > full processing mode
Video > Conversion > 44.1Khz
SAVE WAV
TMPGEnc
Browse Video > AVI
Browse Audio > WAV
Load VCD Template
START -
another favourite cause of this kind of problem is framerate mismatch between the downloaded avi and the framerate of the final mpeg. For example, if the avi is PAL at 25fps and you use TmpGenc with the NTSC VCD template at 29.97 fps this is exactly what will happen. Check the framerate of your avi and use a template with a matching framerate to see if the problem goes away.
What is the best virtual surround sound from a motherboard or a sound-card?
By MarcMiller in forum ComputerReplies: 0Last Post: 19th Jan 2012, 22:03 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 15:29 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 12:58 -
AVI - sound with VLC , no sound Toast burned
By BattyRoy in forum MacReplies: 15Last Post: 27th Jul 2007, 21:21 -
DVD LAB : Different sound in different movie (MIXED SOUND): NOT WORKING?
By SteamrollerLive in forum Authoring (DVD)Replies: 2Last Post: 24th Jun 2007, 19:01
Hi Guys
nice 1 bugster av'nt tried it yet but cheer's anyway.
