I used TMPGenc to convert an avi file to mpeg1. I have the sound but no picture. The avi file has picture and sound when I play it. During the conversion no picture showed up -only a black screen. That is what I have when I play the mpeg1. Please offer suggestions anyone.
*tries to put his hair back in*
unload and reload tempg,i had the same problem, and make sure to run the VFP bat file befor you use it.i have been using Sefy's templates(SeVCD)and they have worked well for me.be sure to put in the video and audio source each time you open tmpge as it will show the last one you did but the file are not reloaded.load a temp.,go to settings, advance tab and double click on source range,drag the bar across and see if you have a picture,if you do cool.just set he start frame and the end frame and encode,if you don't try another vers of tmpeg i use the h vers.let us know
MPCHC Video Audio & Video playback Problems
By skorpinok in forum Software PlayingReplies: 11Last Post: 1st Jun 2011, 10:26 -
New to video, several problems
By Tonyeng in forum Newbie / General discussionsReplies: 15Last Post: 1st May 2011, 21:02 -
Video playback problems after installing video editing suite - Please help!
By abeelandig in forum Software PlayingReplies: 2Last Post: 5th Aug 2010, 21:54 -
Horizontal offset problems with video fields in video to DVD transfers
By aussiebloke in forum RestorationReplies: 3Last Post: 15th Feb 2010, 05:33 -
Video Problems!
By The Jazz Drummer in forum EditingReplies: 2Last Post: 13th Oct 2007, 20:32
