    Nov 2001
    Brasil
    Hi,I´ve already read the old post about this topic,but I had no solution to my problem.My problem is that When try to opern the .vdr file on TMPGENC,it says: can´t open of unsuported file.I must be forgeting something.
    I installed Vdub 1.4.10
    Installed TMPGENC 2.56 + VFAFI Plugin
    Installed the HAndler.
    But The file refuses to open in TMPGENC.
    Please someone helpme...
  2. In the Environment settings, disable the Directshow filter, then TmegEnc will be able to open the VDR file.
    Alternatively, you may call your handler file whatever.avi instead of whatever.vdr and you will not need to use the first solution I gave you.
    Lastly, if all else fails, delete the config files of Tmpgenc, reinstall the virtualdub frameserver, restart TMPGEnc and you should be fine.
    Nov 2001
    Brasil
    I´ll give a try and say if it function.But I´m almost shure I´ve already done that .I´ve already tryed out at WInMe,that didn´t have any install of Vdub nor TMPGENC.Installed both plus Vfafi and the same message appeared...
    Nov 2001
    Brasil
    Oh,none of this could help me,but reading other post,I dicovered a Iinl to a MSVCR70.dll file,that I didn't have at my system.After putting it at my Windows/system folder,I was finally able to use the frameserve function...
    Thanks for the help...
