hey,
after cutting my svcd with dvtool,
i burn the file and it is way out of sync in my standalone player. when i hit slo-mo then play again it syncs up for a second or two then goes back out again.
so i demux with tmpgenc and remux with bbmpeg using the standard svcd template....same problem.
the video is a bit choppy and the video is out of synch.
what are the best delay settings to use in bbmpeg, and where should i enter them.
thanks in advance
wow,
no one has had this problem?
i cant believe that.
please!
you must be helping me!!!
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 21:09 -
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 07:54 -
BBMPEG Multiplexer Question
By Krelmaneck in forum Newbie / General discussionsReplies: 16Last Post: 22nd Apr 2011, 23:59 -
bbmpeg xp patch , page not found
By rabbit_hgc in forum EditingReplies: 8Last Post: 15th Jul 2009, 05:45 -
Need Assistance With TDA 3 Audio (and or Audio Settings)
By isamudysan in forum Authoring (DVD)Replies: 0Last Post: 4th Mar 2008, 21:41
