Hello, i am well aware of the fact this might have been covered a million times. But i have read a ton of threads and have gotten mixed reviews about all the card i have been considering, which are:
Leadtek Winfast 2000XP
AVERMEDIA AVERTV STUDIO
HAUPPAUGE WINTV 125-CHANNEL PCI TV TUNER W/DBX STEREO
HAUPPAUGE WINTV 125-CHANNEL PCI TV TUNER W/DIGITAL DIGITIZER
HAUPPAUGE WINTV-GO 125-CHANNEL PCI TV TUNER CARD
I was actually ready to purchase the Leaktek based on about 3-4 good reviews, but they dont seem to go deep into capturing video. I am basically looking for a card that will allow me to put my home movies from a 8mm Sony Handycam to VCD and SVCD if possible. Thanks in advanced for any helps/comments/suggestions.
Almost forgot my Specs:
WinXP: Home
Asus A7V333
Athlon XP 1800+
ThermalRight AX-7
Crucial 512mb PC2100 DDR
eVGA GeForce3 64mb DDR
C-Media 8738 Audio
WD 40gig & 30gig ATA100
Lite On DVD-Rom & CD-R/W
3COM Etherlink 10/100
Promise Ultra100 TX2 PCI
Enermax 431watt PSU
Enermax CS-003-01WB Case
I would go with a WinTV, they have good drivers, and the video quality is good.
Can u be a bit more specific? Here is the site i am going to buy it from www.mwave.com Unfortunately it has to be this site since it is near me and i can do will call and pick up my stuff and pay cash. I dont have a credit card or else i would order online and such. If there are any around $100 mark i might be able to get enough. Also is there any sites where i can check out the WinTV models more thoroughly cause Hauppauge's site doesnt have much info on the cards, and its confusing on top of that.
Help Choosing Capture/Tuner Card...or Other wise
By drtalk in forum Capturing and VCRReplies: 2Last Post: 3rd Sep 2010, 18:46 -
Choosing the right 1080p SD-card enabled Camcorder
By yangp in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 11Last Post: 13th Aug 2008, 20:25 -
choosing a HAUPPAUGE card
By npereira in forum Capturing and VCRReplies: 67Last Post: 31st May 2008, 05:41 -
need advice on choosing a capture card
By specane in forum Capturing and VCRReplies: 3Last Post: 18th Jun 2007, 11:28
