I plugged my digital camera into my computer to get the JPEGS from it to the computer and while installing the software an blue screen came up saying an fatal execption had occurred. The have to pull out power as computer freezes.
Q. Is this becase of my RAM. I only have 64mb of it. PLease Help.
I doubt RAM caused your problem, if ram was the problem you would be able to install the program, but not run it. Maybe defragment the HD, restart your computer, then try to reinstall.
im guessing you have a via chipset on your computer. I have seen this problem before with via usb adaptors. goto via's website and download the usb filter driver. That should take care of the problem (if it is a via chipset)
It sounds like a driver issue to me. Or the software is interacting badly with some other software or windows itself.
Originally Posted by jonod1
Question about using virtual pc to eliminate computers in internet bars
By jimdagys in forum ComputerReplies: 12Last Post: 23rd Mar 2012, 20:11 -
Question on DDR2 RAM
By SE14man in forum Newbie / General discussionsReplies: 6Last Post: 5th Aug 2011, 07:01 -
Simple Hardware question's on Ram and its support.
By avengerevenge in forum ComputerReplies: 2Last Post: 8th Jul 2010, 08:35 -
RAM question
By mvp in forum ComputerReplies: 3Last Post: 7th Jun 2008, 15:03 -
Simple Mplayer Question
By Maikeru-sama in forum Newbie / General discussionsReplies: 6Last Post: 29th May 2008, 21:10
