  1. I mainly use tmpgenc and when it's already formatted widscreen avi I format it using the templete vcd ntsc and it comes out mpeg with full screen, streching the screen making look all bloated. Does anyone know how do I format this correctly so I can keep it widscreen. Thanks in ahead of time.
    Netherlands
    Start your Encoder:
    - Load your movie
    - Video type is NON-Interlace
    - Aspect Ratio is 16:9
    AND KNOW
    Select Other Settings
    Change the Video arrange Method to Full screen (keep aspect ratio) if you wan't the movie to look exact the same as the video source
    Good luck 8)
  3. THANK YOU SO MUCH, IT WORKED.
