I would like to make my svcd to vcd. I know that there is a guide and I have already referred to it and downloaded the reccommended software. However, my svcd is already on a disk and I no longer have the mpeg2 file. Would it be easier to try and download the file again, or to try and follow the guide to convert?
Thanks,
budgirl357
You may not think you still have the MPEG-2 files, but dig into your SVCD and you'll see a folder called "MPEG-2". In that folder, there will be at least one file something like this:
AVSEQnn.MPG
That's your MPEG-2 file (or there may be more than one if the was more than one used to author the SVCD). Copy it/them to your hard drive and get to work!
Here's more info on what all those folders are for:
[ur]http://www.cdrinfo.com/articles/svcd/page2.shtml[/url]As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Thanks mirror, for the tip. I will definatley read up on the link that you shot me!
regards,
budgirl357
VCD to DVD (not SVCD)
By noyou in forum SVCD2DVD & VOB2MPGReplies: 20Last Post: 19th May 2009, 16:56 -
Problems Converting AVI to SVCD
By wiseguy109 in forum Video ConversionReplies: 3Last Post: 6th Oct 2007, 14:17 -
error encoding while converting avi to svcd
By joannekhow in forum ffmpegX general discussionReplies: 4Last Post: 1st Oct 2007, 11:41 -
avi to vcd/svcd
By neynme in forum DVD RippingReplies: 7Last Post: 26th Aug 2007, 20:25 -
Burning SVCD to a DVD (Not converting!)
By bebopdeluxe in forum Newbie / General discussionsReplies: 4Last Post: 2nd Aug 2007, 09:06
