Ok so when you use the Super VCD template the standard is 480x480 right. Well I take a .mov file from the web that is 16:9 widescreen and it maintains its ratio just fine as it has large black sections above and below.
BUT...
When I use an avi I exported from Premiere that is NTSC 704x480 even though the setting in config is fit to frame maintain aspect ratio my video isn't kept at a 1.46 ratio it is squished to a 1 ratio.
Am I doing anything wrong? I'm going to try the unlock.mcf file tonight and change the size to 704x480 but I don't think this is the way to do things.
Thanks for any advice, graeme.
Results 1 to 1 of 1
Downsizing from 1280x720 while maintaining 16:9 ratio
By pooksahib in forum Video ConversionReplies: 13Last Post: 22nd Dec 2010, 14:18 -
Lines in TS to avi conversion output
By sg_joyce in forum Video ConversionReplies: 3Last Post: 19th Dec 2009, 09:43 -
Joining AVI files, what should the output width/heighth ratio be?
By proudfrog in forum EditingReplies: 5Last Post: 17th Mar 2008, 23:48 -
Help ! Maintaining my original frame size and aspect ratio
By holeepassion in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 9Last Post: 20th Feb 2008, 03:43 -
Mpeg-2 conversion with TMPGEnc: output too bright
By Novie in forum Video ConversionReplies: 10Last Post: 23rd Nov 2007, 10:31
