  1. HELP PLEASE!! When Im creating 2 or more menu screens with NERO, I Am unable to select between them using the 'NEXT' & 'PREVIOUS' buttons on my remote, even though they are there. Can anyone help??
    Steve
  2. I have only been able to get the Next and Previous to work with VCDEasy. There is documentation for this in the Author link to your left.
    At least I think its a bit easier. With some good examples.
  3. Use the numbers on your remote (1 and 2) instead of next and previous.
  4. Originally Posted by dom67911
    Thanks dom - but can I still use Nero to burn VCD afterwards?
    Steve
  5. Using VDCEasy should not cause any conflicts with any other burning tool.
    I have only seen this problem once, but the person had 4-5 burning software on his machine. He ended up having to uninstall everything and use his 2 favorite ones.
  6. Thanks Dom - will give it a go.
    Steve
