If this site was written by a NON techie then you would have less newbie posts!
So far I have not seen a easy set 1 step 2 step 3 step 4 process.
So far I have not seen the question answered correctly with a yes or no answer!![]()
The question being.
Can we use a CD burner in my case I use Nero with the TDK VelCD.
But thanks for VCDHELP.COM!!!!!!
And the Add a Poll makes no logical sense and you must think like a programmer to get he thing working and even after addding a poll you are left with the uncertain feeling ,"IS IT SETUP RIGHT?"
Results 1 to 10 of 10
well that's because there is no easy 1,2,3,4 step. If you think you can build a better site, have at it buddySo far I have not seen a easy set 1 step 2 step 3 step 4 process.
ONLY A NEWBIE WOULD ASK A QUESTION THAT CAN
NEVER BE ANSWERED......WHAT IS IT UR TRYING 2DO? -
There was no question even asked. If you are going to ask a question ask don't beat around the bush. And if you can't follow the guides on this site you must be illiterate because these are the best newbie friendly guides out there. For example go to www.doom9.org and look at some of their guides not as easy but I can still use them because I can read.
It seems that the original poster may be pulling a cork a bit too early in the morning. It's not a bad idea to get all of your typing out of the way, then crack open the bottle.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
Can you use your cd burner?Originally Posted by brianhustis
What do you want to use your cd burner to do?
If your asking if you can use your burner to create a VCD than the answer is more than likely yes. If your asking if your CD burner can create a DVD then the answer is NO. But if you want to know what your CD burner can and cannot do then you should refer to the instruction booklet that came with the burner.
As far as the site being written by a techie. I would say that the subject matter requires a basic level of computer skill and understanding. If you do not have such skill or understanding, I suggest you read a book on the subject and come back later.
In answer to the question[Can we use a CD burner in my case I use Nero with the TDK VelCD.] Yes you can, you can use it for any purpose that a burner is capable of. Eg, vcd's, svcd's, xsvcd's, but not for DVD thats why you need a DVD burner.
If your wondering how to do any of the above check out on the left rhe Newbie Guides, you'll be amazed at what you can learn.[/quote]Welcome my son, welcome to the machine. -
step 1, open pack of CD's
step 2, remove 1 CD
step 3, press button on fron of drive (This ejects the holder)
step 4, place blank CD into tray
step 5, press botton on fron of drive again (this closes the holder)
BRB -
LOLOriginally Posted by KingJohn
I'm sure he could use the break, I know its a lot of info to absorb all at once!
RiG -
is the question can you use nero with the velocd? if so i'm guessing that yes
#videohelp on dalnet!
Simple task, not so simple (rip/quicksync)
By Trife in forum Newbie / General discussionsReplies: 10Last Post: 12th Aug 2011, 20:57 -
first steps in simple editing: from vro to dvd?
By lightningbit in forum Newbie / General discussionsReplies: 7Last Post: 17th Aug 2009, 12:56 -
Adding extra material to the end of a simple 1 movie dvd (with simple menu)
By ColinKe in forum Authoring (DVD)Replies: 4Last Post: 24th Jul 2009, 23:38 -
Military or medical techie question
By DeadLily in forum Off topicReplies: 3Last Post: 12th Mar 2008, 09:51 -
Which steps should I use?
By Belfour in forum Newbie / General discussionsReplies: 5Last Post: 5th Jun 2007, 10:33
