I've been using tmpgenc12a up till now. I d/l tmpgenc v12i and ran the install.bat but cannot open any type of video files, mpg1, mpg2, avis or divx. I get message "unable to open or unsupported file."
What am I doing wrong??
Did you also download and install the VFAPI plugin for version 12i as well?
I wonder if its Version 12i itself? So many are having this problem. I presume you have checked that the VFAPI facility is checked in TMPGEnc?
aldus4
I much appreciate you help. Yes, the VFAPI facility is checked.
Strangely tmpgenc is now recognizing files though I haven't changed any of its settings. Had this happen to me before and then mysteriously stopped working after my first short encoding test. Hope it stays working now...
Thanks for your interest.
I'm having the exact same problem with 12i. I was encoding a SVCD capture to VCD, then I aborted the encoding and exited TMPGEnc. When I restarted TMPGEnc, it wouldn't open the SVCD capture and gave me the same error message "unable to open or unsupported file"
I can open the SVCD capture with no problem with 12a.
RF -
Found a workaround for this problem
http://www.vcdhelp.com/phpBB/viewtopic.php?topic=53750&forum=3
Getting the best results from TMPGEnc 2.5 on 2 AVIs
By buddycat in forum Video ConversionReplies: 28Last Post: 7th Nov 2010, 18:30 -
Ripping DVDs as MPEGs using TMPGenc --- loss in quality?
By DieselsDen in forum DVD RippingReplies: 5Last Post: 21st Sep 2010, 13:09 -
Joining two AVIs in TMPGEnc Xpress
By jeanpave in forum Video ConversionReplies: 17Last Post: 9th May 2010, 00:16 -
TMPGenc crashes when opening avi
By Kromgol in forum Video ConversionReplies: 4Last Post: 19th Jul 2009, 10:03 -
Trouble opening avi in Tmpgenc 3.0 Express
By davexnet in forum Video ConversionReplies: 1Last Post: 11th Dec 2008, 12:07
