  1. The Mustang King arcorob's Avatar
    Dec 2001
    Seattle
    Greetings,
    I use AIW card and capture to AVI. Then I use TMPG to convert to VCD. All works well EXCEPT I notice that it always has a tiny bit of a rolling line at the bottom of the screen. It is as if the source Video tape was raised a hair and you see the edge of the tape roll by.
    I know there is filter to get this out but not sure where I read about it or why it occurs. It is annoying !
    Thanks for any and all help....Rob javascript:emoticon('')
  2. It's the video head switching points. The only way to remove it is to cover it by blanking the bottom lines (vdub). Since the bottom lines never shows on a TV set, it's normally not a problem.
  3. The Mustang King arcorob's Avatar
    Dec 2001
    Seattle
    Thank you ...I will burn the first part and try it....Heres the kicker. I had to buy a SIMA image enhancer too...Seems the guy who made the wedding video added COPYGUARD....Hows that for a kick ???
    Thanks again
  4. Not even I would add Macrovision to a wedding video...
