I ripped a DVD using SmartRipper and used GKnot to encode it and all, and when it was done I had an AVI file with no sound. The log said that there was an error putting the audio in with the video and that I could do it later. I'm assuming that the .AC3 file contains the audio that I need, but I would like to know how I would append an audio file to an AVI.
Any help on the subject would be appreciated.
Thanks.
depends if you want to keep the .ac3 or not in the avi/divx file
if not (simple way)
<<----- tools on the left, download azid
open a command window and type azid filename.ac3 filename.wav
when that is done
open virtualdub www.virtualdub.org
open avi in virtualdub, select menu: VIDEO/DIRECT STREAM
select menu: AUDIO/WAV AUDIO and point it to your .WAV file
select preview (play1 button) to see if the audio is in sync
if it is,
select menu: AUDIO/FULL PROCESSING then set your compression (mp3) and bitrate and if you downsample from 48->44 select that in menu: AUDIO/CONVERSION. Personally I wouldn't bother as 48 is OK.
now encode the video (audio actually)
if your audio is not in sync, look in the menu: AUDIO/INTERLEAVING and select a delay time for the audio to start at.
if you need the audio to start sooner, try -300 in the audio skew box and work your way up or down with the preview button. same if you need the audio to start later, just don't put a - in the number.
OK if you want to keep the ac3.. welp gotta ask someone else :P sorry. I have only downloaded them, I have never needed to make one yet.
Appending audio/video data to an MKV file
By urymf in forum EditingReplies: 5Last Post: 6th Oct 2011, 10:35 -
trouble with audio after appending a .jpg turned .mp4 to another .mp4
By canadianjameson in forum Newbie / General discussionsReplies: 7Last Post: 26th Jun 2011, 10:55 -
removing the commentary audio track from an AVI file with mpeg layer3 audio
By wildrthanevr in forum AudioReplies: 1Last Post: 10th Mar 2009, 02:29 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 16:38 -
appending avi segments w/virtualdubmod
By burgkev in forum Newbie / General discussionsReplies: 2Last Post: 13th Jun 2007, 14:14
