I just made a vcd using nero. I didn't do chapters or anything and I put it in my dvd player and is reads "no disk". My dvd player does support vcd's and I was flipping through the manual and it says that I must turn off PBC. However, it does not tell you how to turn that off. Anyway, for some reason I cannot get my vcd to work. Any suggestions?
Oh, and I have a cheap apex dvd player if that helps. Thanks.
Is it a super-cheap one, without a model number? If it had one, we could look it up in the manual (since we'd know which manual to grab), because I'd almost bet the farm that it tells you how to toggle the PBC.Originally Posted by demonomania13As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Make sure your DVD player is capable of playing CD-R or CD-RW media. To test, try burning a regular audio CD on a CD-R or CD-RW. If it can't read that, then you won't be able to play VCDs on CD-R either.
DVD Player problem playing .avi
By dexter30 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 17th Sep 2009, 01:18 -
xvid avi problem when playing on eternal dvd player
By myname77 in forum Newbie / General discussionsReplies: 2Last Post: 16th Sep 2008, 11:26 -
problem playing Philoco dvd player moga juniour 400
By akhtar123a in forum Newbie / General discussionsReplies: 1Last Post: 6th Aug 2008, 10:17 -
Playing DVD burned slide show on DVD player problem
By zenfoos in forum Newbie / General discussionsReplies: 4Last Post: 29th Aug 2007, 22:37 -
Problem with playing DVD in standalone player
By tngolfn in forum Newbie / General discussionsReplies: 2Last Post: 14th May 2007, 18:41
