Hi,
I've got 2 questions.
1.
I read the CVD guide and i saw thats there a tool which calculat the Q.But which bitrate should i now use?
2.
How do I burn a CVD?
The bitrate calculator will tell you the filesize, you set the bitrate to fit the movie on 1, 2, 3, or more disks depending on the length on the movie and the quality you desire. Remember its 800 MB per disk.
Many ways to burn. I remux with bbMPEG, make an image with VCDimager, then burn the bin/cue with Nero. For the first two I set as for SVCD. bbMpeg seems to cure audio synch problems, VCDimager makes FF/RW work. SFAIK any burner prog will use the bin/cue. -
hmm can i burn the cvd .mpeg file with nero as an svcd or how should i do that without .cue and .bin ?
and for example i got a movie which length is 100 min.audio bitrate is:128 kb.2cds.80min.which Q should i now take? -
You can burn any CVD file in Nero by selecting the SVCD option. Also uncheck "Make Compliant SVCD" box before you start importing your files.
Few questions regarding LCD tv... that will lead to more questions :)
By ohlookyhere in forum DVB / IPTVReplies: 16Last Post: 15th Aug 2010, 15:50 -
Anyone mirrored or saved OGT/CVD subbed test images?
By zinchronized in forum Newbie / General discussionsReplies: 5Last Post: 11th Aug 2010, 22:46 -
Looking for test SVCD images with CVD/OGT subs
By zinchronized in forum Authoring (VCD/SVCD)Replies: 0Last Post: 11th Aug 2010, 07:55 -
Powersupply questions and fan questions
By yoda313 in forum ComputerReplies: 39Last Post: 8th Sep 2008, 18:08 -
Quality loss VHS > CVD, DVD
By rglmrj in forum Video ConversionReplies: 15Last Post: 1st Jun 2007, 12:13
