  1. Hi !
    I want to convert my SVCDs to CVDs - pls don't ask me why...
    I get the mpeg 2 files off my SVCD with DVD2AVI.
    I save the project and convert the project with VFAPI.
    I open the dummy-vfapi-avi file with Virtual Dub 1.4.8.
    I apply filters (resize).
    When I want to click "start frame server" Virtual Dub crashes!!!!!
    Please help me! PLEASE!!!
    Med.
    P.S.: If I load a regular avi I can frameserve without any troubles!!!
  2. I'm not sure I know why you are doing what you are doing, why not just use DVD2AVI and re-encode the file in TMPGEnc to CVD ?
    Email me for faster replies!
    Best Regards,
    Sefy Levy,
    Certified Computer Technician.
  3. Hi Sefy !
    The solution to my problem seems to be that I didn't close
    DVD2AVI after saving the project. Anyway now it works 8)
    The reason why I use VD and CCE is that I think (/thought if
    you do convince me ) VD's Resize filter is better than
    TMPGEnc's and CCE's mpeg2 encoding is crispier than TMPGEnc's.
    However, when it comes to VCD/mpeg1 I always use TMPGEnc!
    Thanks for your reply!
    Med.
  4. The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    SVCD to CVD has a lot of quality loss! Ain't worth it if you ask me...
    If you have the source, do it all over again...
  5. Hi !
    Yeah, Quality loss is indeed a Problem but unfortunatly
    I recorded over and over again on my miniDV tapes.
    (Either I should go less often on holidays or I should buy
    more tapes . From now on I make only CVDs. so
    I can go and pack my bags again )
    best wishes,
    med.
  6. The Old One SatStorm's Avatar
    You lucky ....
  7. All my bags are packed, I'm ready to go..
    Cause I'm leaving on a jetplane...
    Ouups! did someone listen to my singing
