Sorry to be a pest and all, but I want to know what is the best possible setting that I can use to make my VCD high quality. I want to know if It is necessary to make the VCD file smaller to fit the test or will most dvd players atuomatically set it to fit the tv screen?
VCD standard is 352X240 NTSC or 352X288 PAL
when you encode (with tmpgenc) it will automatically make it so it will fit the TV screen if you select Full Screen Keep Aspect Ratio - bear in mind that if the source is whide screen it will also be widescreen on the TV (which i personally prefer because you get to see the "whole" movie as it was in the cinema. if you are encoding divX's which tend to have all sorts of wierd aspect ratios, choose 1:1 vga for SOURCE and 352x2xx for the encoded video. look at the conversion guide on this site for VCDs -
all well and good if your tv don't overscan. If it do your gonna need to look at resizing. Do a search on overscan. Plenty of reading.
MKV to BLURAY highest quality
By Mikey0124 in forum Newbie / General discussionsReplies: 5Last Post: 10th Mar 2012, 16:47 -
Highest quality backups
By freewave in forum Newbie / General discussionsReplies: 4Last Post: 13th Mar 2010, 20:32 -
Highest quality codec
By chizzle in forum Blu-ray RippingReplies: 6Last Post: 11th Feb 2009, 16:57 -
Compressing with the highest quality
By guitarscn in forum Newbie / General discussionsReplies: 6Last Post: 26th Apr 2008, 15:02 -
How do I capture Sky Tv at the highest possible quality?
By Gun in forum Capturing and VCRReplies: 0Last Post: 17th Sep 2007, 13:45
