I hve been using the following hardware till now:
- ECS K7S5A Lan Sound
- Athlon xp1700+
- 512MB PC133
- AGP Voodoo 3000
- DV500+
- AHA-2940U
- SBLive! 5.1
- WinTV
This however isn't wokring with XP with programs such as TMPGEnc en Cinemacraft. (IRQL_... bluescreens en instant reboots). These problems also showed with a clean XP install with only the SCSI card, the DV500+ and the Voodoo 3000. So I think the problem's in the Voodoo 3000.
Now I'm planning to buy a ECS KVTA3 (Via KT333 chipset). What videocard do you recommend (low price, I'm not going to play games). I will keep on using the DV500+ and the AHA-2940U and the SBLive! if possible. The WinTV isn't necessary anymore. It must be fully compatible with XP.
Is the Club3D Nvidia MX400 a working one?
I have a similar setup with K7S5A with tbird 1100 512MB of PC133 with Gforce2Ti. This machine has been very stable for encoding with TMPGenc 2.55. I expect you problems could be with the voodoo card or drivers, do you have an alternate card to try?
i haven't got another video card to try it with. (yes I've got an Voodoo Banshee.......but that's even older, don't think that's gonna work)...
Have you tried running without the capture card and/or SCSI card. It might not be just the Voodoo but a combo of cards.
If you are buying a new card you can pick up a current generation nVidia or ATI based card for your needs for >$100 or a Gforce2 or 3 card for less and still get good results for vid playback and play the occasional game.
AccountKiller
By rcvalle in forum MediaReplies: 3Last Post: 13th Dec 2010, 22:05 -
my current camera (jvc gr dv500) is messed up. making noises n weird lines
By bojadada in forum Newbie / General discussionsReplies: 4Last Post: 24th May 2009, 11:09 -
ECS GF8200a Mobo will not overclock w/ BE AMD 64 X2 5400...
By stedyone in forum ComputerReplies: 17Last Post: 27th Mar 2009, 03:40 -
Pinnacle DV500 Plus crashes on installation
By Dr.Rock in forum Capturing and VCRReplies: 2Last Post: 12th Feb 2009, 13:27 -
Recommended Chain for Hardware processors
By mbself in forum RestorationReplies: 6Last Post: 30th Jan 2009, 21:38
