  1. hi,
    I converted some mpeg files to dat and copied to a CD using EasyCD creater, But when i try to play in my VCD player it says "no cd inserted".
    Can anyone help me to run this in a VCD player??
    regards
  2. You cant just copy the files across to the CDR and burn it as a data CD (mode 1), you have to select to burn a VCD (mode 2) in the burning software that you are using. I don't think easy cd creator can do VCD's unless you have the deluxe version, and I would'nt bother getting that. Get hold of a copy of Nero, you will have to uninstall easy CD creator befor you install nero. Use nero to burn your VCD, just select VCD from the menu, drag your mpeg's across and burn.
    Craig
