wen i framesever de movi colle damage van swarsenegger dan wen it is finish i have a problem with the syncron of sound and vision.
de avi file is oke only i get a vbr error in virtualdub but i try to get this a we but i dont no how.
so de orionel is goed dan virtual dub sy a vbr error
than i can framsever toe tmgenc bud when it is redy th movie is not syncroon (sound and vision).
i no that as i get a vbr error i can do the nex step
video streaming
audio full procecing
sav avi as
and than us this avi file for framserving but then i get the same problem
the sound and vision are not syncroon after i look at de mpeg file.
sorry for the bad english
you also can mail me at groninger@hetnet.nl
hi. im having the same problem (vbr error in virtualdub) but the guide in http://www.vcdhelp.com/divxtovcd.htm won't help.
i tried full processing mode and direct stream to extract wav from the .avi. then i use tmpgenc with my .avi and my extracted .wav but i still get out of sync mpg.
ive been lookin in this forum but still can't make it to work. please help. -
Does the sync problem get progressively worse or is it out of sync for the same amount through the entire movie.
Craig -
I seem to rememeber a info post about this on the VirtualDub web site.
Something about AVI not fully supporting VBR audio
check the VirtualDub web site - technical support page for more info -
in some movie it's only in the begin of somewher in the movie.
but thera are some movie like blade 2 i have it the hole movie.
i also had it bij from hell.
and with colleteral damges
can it be that the movie is ript with 5.1 ac sound???
becourse i could not frames server only use virtual and sub to make a avi with sub and than ik can use tmpgenc and make the mpeg movie.
on min older pc p3 500 win 98 se i dont had this problem
now i use p4 1500 xp home
Frameserving From VirtualDub to MainConcept
By hech54 in forum Video ConversionReplies: 0Last Post: 8th Mar 2012, 09:24 -
Problem with Virtualdub
By pranjev in forum Newbie / General discussionsReplies: 25Last Post: 30th Dec 2011, 12:16 -
VirtualDub Problem
By jarko in forum Newbie / General discussionsReplies: 1Last Post: 8th Jan 2010, 12:26 -
problem w/virtualdub
By motleycool in forum Newbie / General discussionsReplies: 2Last Post: 7th Apr 2008, 23:09 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 17:08
