    Jul 2002
    Italy
    Hi ! I having a problem using xing mpeg encoder . at 98% of my avi stop the encoding and says : The video data rate is too low to encode this file. Try encoding again using a profile with a higher video data rate.
    I want to make a vcd and the video datarate is fixed . what im doing wrong ? Thanks .
    Jul 2002
    Italy
    no one can really help me ? I have the napa 309 and tmpeg and other encoders have problems with napa . I m really desparate . I tryed also the site http://www25.brinkster.com/fletchlinks/napa311/ but it didnt worked out Im trying to make vcds from divx ... Now im trying with panasonic encoder but is slow as hell . Is there any possibility to see vcds (made from divx) with another encoder faster. The prob with xing seems to have an logical solution no ? PLEASE help !!!
    Feb 2001
    Berlin, Germany
    I don't think, that many peoples here use the xing encoder. Also I dont think, that your dvd player has problems with the MPEG encoder. The problem is rather the way how you have multiplexed the MPEG and -even more important- how you have authored and burnt the MPEG to VCD.
    Jul 2002
    Italy
    nope is the napa . I made 20 vcds to test it . I used the guides that i found here . All 20 vcds are playing in the pc but not in napa . Napa is problematic . Take a look here : http://www.tmpgenc.net/cgi-bin/ebbs/board.cgi?board=tmpgenc (put on search box thew word : napa) . Only two encoders are good enought to produce an vcd playable with napa :
    a) Panasonic encoder works perfectly but it is slow .
    b) xing that works till one percentuall and then stops and says :
    Now all the cds that i made have not asynch probs etc . The trick at the brinkster site dosent work so the existence and only of that site means that napa is problematic with 80% of the encoders. Napa is also problematic with CCE /tmpgenc/LSX MPEG Encoder Suite 2.0
    so what can i do ? I think that the prob at xing is rather silly to fix ...
    thanks anyway !
