ok well here is the qestion , i have a Apex dvd player with the hack so i can play all region dvds... and well i orderd a dvd from the uk and its a region 3 dvd.. so now the question is will i be able to play it on my dvd player cause the dvd is pal and my player is ntsc????? do i have to do something to watch it or what??
APEX should be good for all. But other Branded like Pioneer, JVC, won't unless they are of Asian model.
Actually UK is region 2, but PAL nontheless. Nearly all DVD players will play PAL and NTSC disks but many output the signal type that matches the disc format. So unless your TV can handle PAL you may end up with a black and white picture/vertical scrolling or no picture at all. I don't know the apex player but some DVD players can be configured to output all discs as PAL or NTSC regardless of the disc format. Take a look at your players manual/options menu, you might get lucky!
Pal 25i to Ntsc question
By spiritgumm in forum Video ConversionReplies: 17Last Post: 15th Dec 2011, 19:16 -
PAL to NTSC question
By rayden54 in forum Newbie / General discussionsReplies: 11Last Post: 2nd Apr 2011, 22:59 -
PAL vs NTSC Question
By cottage in forum Video ConversionReplies: 26Last Post: 6th Jul 2009, 10:53 -
Pal/Ntsc DVD Recorder question
By ArtieEngh in forum Newbie / General discussionsReplies: 1Last Post: 19th Dec 2008, 11:18 -
Total Noob Question - NTSC / PAL
By fredfillis in forum DVB / IPTVReplies: 15Last Post: 10th Jan 2008, 06:16
