ok here's the process i went through so you know what i did.
>i decompressed the avi audio using the decompressor that comes with avi2vcd (ive also tried virtual dub 2 change the audio to wave format)
>converted the newly made file from the avi decompressor to svcd format following all the directions given in vcd help(or maybe i missed some)
>anyways the svcd file i made was very shaky or jerky "whatever" and the audio sync was way off.
If you have any suggestions please reply
THANK YOU
love peace and chicken grease![]()
DVD playback problem, possibly a file structure problem?
By snuhmcsnort in forum Newbie / General discussionsReplies: 8Last Post: 17th Aug 2010, 05:23 -
problem after problem - dvd architect, not enough room in temp files
By jgeck90 in forum Newbie / General discussionsReplies: 7Last Post: 1st Dec 2008, 04:35 -
HDD problem, gigabyte's easy tune major problem and etc....
By MidnightMike in forum ComputerReplies: 4Last Post: 28th Jul 2008, 22:57 -
video card problem causing watching movies problem?
By vipertongn in forum ComputerReplies: 3Last Post: 11th Jun 2008, 12:39 -
WinTV PVR 150 problem and Geforce 7600 GS problem
By deck in forum Capturing and VCRReplies: 5Last Post: 16th Jun 2007, 04:03
