Tmpeg allows you to open VOB directly and encode them to SVCD.
You have to rip the movie as one file because Tmpeg will only open one VOB a ta time. This works on some movies,they open and I can encode the whole movie to SVCD. Some movies won't open correctly however. Tmpeg only sees the first few minutes instead of the whole movie. What causes this? Is there a way to correct it/
I've tried IFOedit with no success.
try this method.
http://www.vcdhelp.com/mpeg2tovcd.htm
note: even though it says dvd2avi in the guide, you do not save to avi, your only making a d2v file, which is basically a map of the mpg for tmpgenc to follow. the mpeg2 plugin in tmpgenc is kinda buggy, so its best to use this step -
oh btw, if your target is svcd, just use the svcd template instead of the vcd one
DVD2AVI is the problem. Creating a D2V with it introduces all kinds of macroblocking and motion artifacts. Opening the VOB directly in Tmpeg eliminates all these artifacts and yields a much better quality SVCD.
Opening .flv in VirtualDub ?
By GMaq in forum Video ConversionReplies: 24Last Post: 13th Feb 2012, 07:07 -
opening a port
By aruwin in forum ComputerReplies: 8Last Post: 30th Oct 2010, 06:54 -
Opening a file
By ahidayat in forum Newbie / General discussionsReplies: 1Last Post: 2nd Mar 2009, 04:33 -
Opening Movie
By Gunna in forum Newbie / General discussionsReplies: 7Last Post: 13th Sep 2007, 17:08 -
Inserting Opening
By zirkov in forum Video ConversionReplies: 2Last Post: 27th Jul 2007, 13:53
