HI, I am having audio/video sync problems when '0 transform' to crop mpg1 video in VirtualDub. I like to remove that noise line at the top of the screen that I always get when I capture. The cropping works great, a/v always goes out of sync. Is there any way I can prevent the a/v from going out of sync or are there any other progs I can use to crop my mpg1 streams with ?
P.S. I don't have any other background apps running.
Thanks,
FUG
Hi fugoff !
Maybe this is not directly a solution
to your problem but a workaraound:
Capture without cropping in Virtual Dub,
instead use "crop video" in TMPGEnc's
advanced menu.
Med. -
I've never noticed that before
That should work perfectly. I really appreciate the reply. Thanks a lot!
Cropping Ability with Womble MPEG Video Wizard DVD
By montgal in forum Newbie / General discussionsReplies: 3Last Post: 1st Apr 2010, 23:11 -
Question - Capturing to MPEG directly with VHS cropping
By joejoe in forum Capturing and VCRReplies: 2Last Post: 24th May 2009, 23:45 -
cropping
By mwh99 in forum EditingReplies: 2Last Post: 7th Nov 2008, 13:25 -
Cropping DV
By bsuska in forum Newbie / General discussionsReplies: 1Last Post: 13th Feb 2008, 11:31 -
using virtualdub mpeg-2 for cropping and need advice
By mrgain in forum EditingReplies: 2Last Post: 10th Jun 2007, 11:59
