I used graphedit to convert a movie in ogg format to avi, but had to have the audio done in wave format. for some reason graphedit wouldnt convert with the mpeg3 in the formula. Anyways now I have a rather large 3 gig movie with the audio in wave format. Read that I can convert the wav to mpeg3 usuing virtual dub but cant figure out how to do that. Are there any good step by step guides out there showing the process? Also when converting the audio will my file get smaller than 3 gigs?
Thank you, thank you, and thank you heh. Only one question, once I get my separate wave file, am I basically stuck with a 3 gig movie? or will using tmpgenc make it smaller?
Okay that didnt work
Made the wav file with virtual dub, but TMPGenc wont open it, says its unsupported. Any ideas?
~edit~
Noticed under the audio virtual dub wont let me save the wav file under full processing. Could this be my problem? It will only let the file save under direct stream.
decode 5.1 matrix surround wav file to 6 mono wav files
By Zerrax in forum AudioReplies: 2Last Post: 24th Nov 2013, 07:39 -
converting movie ntsc>pal audio-besweet "wav to wav" option not showing?
By extent in forum Newbie / General discussionsReplies: 2Last Post: 11th Jun 2010, 12:38 -
Some questions on converting DTS WAV files
By smackyourfupa in forum AudioReplies: 3Last Post: 17th Mar 2010, 09:04 -
Converting WAV to MP3
By igorek in forum AudioReplies: 5Last Post: 1st Jun 2008, 20:25 -
questions on converting RM files
By sprilite in forum Video ConversionReplies: 2Last Post: 9th Mar 2008, 22:08
