i have xp and have downloaded and installed adaptec aspi, version 4.6 and 4.7. but vcdeasy still does not recognize them as valid. The more info button says i should be able to force my burner to work.
There should be a tool that comes with the Adaptec download that checks your ASPI installation (ASPICHK.EXE or something like that). What does it say?
Many people have had similar problems with the Adaptec download. ForceASPI (which also installs the same ASPI layer) seems to work well with WinXP. You can download it from http://www.doom9.org
Regards.Michael Tam
w: Morsels of Evidence -
Highly recommend FORCEASPI
I had the EXACT same problem with VCDEasy while running Windows XP Professional. I installed ForceAspi, and everything worked like a charm. In the ForceAspi readme html file, there's also a link to get that ASPICHK.EXE program that checks to make sure that your ASPI is working correctly.
Good luck!
Mojo
my pc wont recognize my sony handicam dcr-hc21
By J.Frost in forum Capturing and VCRReplies: 3Last Post: 21st Dec 2009, 00:27 -
convertx wont recognize avi
By brdhsby5 in forum Video ConversionReplies: 4Last Post: 20th Aug 2008, 18:01 -
Updated PowerDVD wont play HDDVD backups
By aye29 in forum Newbie / General discussionsReplies: 1Last Post: 10th Dec 2007, 05:58 -
comp wont recognize older cd's & dvds
By lawzfeehily in forum Software PlayingReplies: 6Last Post: 12th Sep 2007, 17:56 -
DVP-5982 Wont recognize Extern Hard Drive?? Any help?
By ebayork in forum DVD & Blu-ray PlayersReplies: 3Last Post: 17th Jul 2007, 23:14
