Ok first of all i have a avi (final fantasy) which has some bad frames at the end, and it wouldnt convert in tmpg unless I cut them out so I did with virtual dub.
Ok i openened the avi and found the bad frames and deleted them, then i selected direct stream copy in the video.
So it saved it and everything looked fine until i played the new avi. And every like 5 seconds it will get this green tint and then vanish. But it will keep coming back.
I have tryed reduing it with virtual dub but it always comes out wrong am I doing something wrong or does virtual dub give a major loss in quality?
-Mike
Please help.
ps it still plays but it has that weird green effect.
What codec do you have installed? I know the angelpotion codec causes purple tints and I swear I've read that it causes green tints also.
you mean the one i use to view the divx
its 3.11 alpha
i think i put in beta 4 in too what should i use -
its also kinda freezing when i try to recompress the avi with the divx mpeg 4 slow motion codec
give me instructions on how to get it to work please -
first of all if you are using the divx codec make sure it is not a hacked or the open source one. these codecs tend to not work good and suck. use a codec like a microsoft one such as indeo 6, or one of the other ones. depends on your machine too. if you have a slow machine, which you might, it won't work well. hope this helps
colors are too bright in capture, greenish tint?
By twinkie09 in forum RestorationReplies: 4Last Post: 27th Feb 2010, 02:00 -
Some of my DVDS are playing with this weird red tint
By hatazcat in forum Newbie / General discussionsReplies: 18Last Post: 26th Apr 2009, 04:24 -
Software to adjust Color, Tint, Contrast.............
By richards2222 in forum Authoring (DVD)Replies: 3Last Post: 8th Apr 2008, 05:57 -
DVD labeling comes out greenish
By Gswiss in forum MediaReplies: 2Last Post: 20th Oct 2007, 04:11 -
ts / avi into final cut
By marinebc11 in forum MacReplies: 3Last Post: 12th Sep 2007, 09:58
