OK heres my problem:
I've made a DivX to VCD convertion, ( followed the how to on this site VCDHELP.COM ) and then I thought that I could play this "vcd-movie" on my PC, as well as on a standalone DVD-player.
( My PC do play ordinary bought DVD's )
On the CD I've burned there are the following folders / files:
One folder called : Ext
containing:
Lot_x.vcd 64KB
Psd_x.vcd 1KB
One folder called : Mpegav
containing:
Avseq01.dat 536.668KB
One folder called: Segment
This folder is empty
One folder called : Vcd
containing:
Entries.vcd 2KB
Info.vcd 2KB
Lot.vcd 64KB
Psd.vcd 1KB
Does this seems OK? Where did I go wrong.
Which type of file do a VCD player open?
Which type of file should I try to open with my WINdvd?
Will it play on a standalone DVD-player?
THX
Everything is ok. You need to open the *.DAT file in the MPEGAV folder with Windows Media Player if you want to play the VCD on your computer.
Joshua.
Converting FLV Files to DVD Playable Standalone
By Bonie81 in forum Newbie / General discussionsReplies: 3Last Post: 17th Aug 2010, 10:55 -
Problem with end frame showing up at beginning when converting ts to avi
By mt123 in forum Video ConversionReplies: 2Last Post: 27th Sep 2009, 11:54 -
I'm a wits end with HD PVR and the .TS files
By tvconfuse in forum Video ConversionReplies: 0Last Post: 19th Oct 2008, 12:56 -
Problem converting standalone incompatible clip but keep quality
By Mark69 in forum Video ConversionReplies: 6Last Post: 2nd Feb 2008, 10:15 -
Converting for standalone divX player
By yobob in forum Newbie / General discussionsReplies: 4Last Post: 23rd Sep 2007, 12:11
