I finally was able to burn a SVCD (thanks to all those that hepled, it was finally a Memorex CD-RW that worked) and it works very well except that the words lag behind the movie a little bit. Not more than a half second or so, but still very noticable. This was a conversion of a DV-->MPEG-->SVCD
In other words it was a home video so i didnt think there would be any problems. Any ideas? Thanks.
yes, glad to hear someone is having the same problem. im gonna try vcdeasy. good luck
Convert what ever you have using TMPGEnc, using a VCD template, then the mpeg will be correct for programs like Nero to burn it.
MKV2VOB sound problems
By DaxPG in forum Newbie / General discussionsReplies: 7Last Post: 17th May 2010, 15:43 -
Problems with sound on 6ch
By pixiesoft in forum Authoring (Blu-ray)Replies: 3Last Post: 5th Apr 2010, 07:12 -
Sound problems
By maltipom in forum Newbie / General discussionsReplies: 2Last Post: 16th Mar 2009, 13:37 -
sound problems
By deebo in forum Software PlayingReplies: 4Last Post: 9th Aug 2008, 14:43 -
Sound problems
By zewzeq in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 20th Nov 2007, 06:36
