Results 1 to 11 of 11
  1. I have piles of CD's that have no cases and are just labeled with magic marker. I just ordered 200 jewel cases to clean them up a little.
    I would like to make covers for the cd cases so I can see what they are from the small side when they are stacked up.
    Does anyone know what I need, i.e. covers, software, etc?
  2. Search for your covers here
    http://www.mega-search.net/
    Then simply print, I use paint shop pro 7 to print because it lets you resize the covers and print the front and back images in one go.
    You may need to resize the covers, the sizes are.
    Front 12cmx12cm
    Back 15.1cmx11.8cm
    Craig
  3. Thanks Craig, are you just printing them on 8 1/2 x 11" white paper?
  4. I print mine on A4 glossy photo paper.
    Craig
  5. You can also find loads of cd covers, including ones for discs, at www.cdcovers.cc.
    Michelle aka dkjmom <:)
  6. I have links to cover sites on my site below
    Panasonic DMR-ES45VS, keep those discs a burnin'
    thick member?
    food folks and fun
  8. Think about it
  9. Well if you're infering to what I think you are, I always assumed by your name that you were female. So which member are we talking about.
    Craig
  10. http://www.cdcovers.cc i think thats probery the best 1 in the net but i bet no 1 can find Queen Of The Damed DVD Cover cyas
    Apr 2002
    The State of Frustration
    What sort of adhesive is used to stick the labels to the disks?
    Hello.
