I just get done ripping it with smartripper and then I open dvdx and try to open the ifo file. I get this: "error: MPEG2Dec: Error during decoder initialisation"Any help would be appreciated!
Good Luck trying to get help on this one. I have the same problem with a couple of movies that I ripped. I even e-mailed Sefy myself and still have gotten no reply. I really need a solution so I can get the VOB files off my HD.
Michelle aka dkjmom <:) -
ComeON..
5 minutes of your time searching the net would have given you
http://www.labdv.com/forum/viewtopic.php?topic=2802&forum=16
Don't bother poor Sefy, like a certain other being he's done his
6 days of work and now he needs his rest. -
OK. I went to the article and did what it suggested. I opened the mpg (VOB) files. This worked great, the only problem is it doesn't encode the last 5 chapters. So it is basically not encoding the last VOB file. Now what do I do?
Alrighty!!!!! I found a solution. It is a long drawn out process, but it works for this problem. Go to http://www.divx.net.nz/guides/dvd_divx/index.htm. If you have problems finding the down loads for any of these please send me a private message and I can send you the files via e-mail.
dkjmom, I am terribly sorry! if I have recieved your email, it's propably in the long list of emails, no matter how many I answer, there are always more coming in, and i'm not able to help everyone.
I am glad to hear you found a solutions, and i'm sorry I wasn't able to help.Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
One more thing I forgot to tell you. If you do decide to go this route, download Gordian Knot first. It has several of the programs you need to go through this process. Then figure out what else you need and download it separately. Another good site, which has all the downloads for this is at http://download.everwicked.com/ Good luck and have fun.
DVD FLICK, Start-up Error Msg-Unable to created txt file. Last DLL error: 5
By jacknscoob in forum Authoring (DVD)Replies: 5Last Post: 4th Mar 2012, 08:58 -
Error: The source image format is not acceptable (error code -2)
By Russo in forum DVD RippingReplies: 3Last Post: 5th Jul 2011, 10:50 -
BD REbuilder ERRor - Error in attempt to extract audio/subs.
By ajhansen91 in forum Blu-ray RippingReplies: 1Last Post: 26th Mar 2009, 14:39 -
Where to find mpeg2dec.dll
By jwfc in forum Newbie / General discussionsReplies: 3Last Post: 12th Nov 2007, 00:58 -
Get many error messages, AviSynth error message and meGUI error
By MKVcrazy in forum Video ConversionReplies: 0Last Post: 25th Aug 2007, 16:41
