Hi, I want to buy DAZZLE VIDEO CREATOR 80, can this product capture about 60 to 120 mins of VCR continous and is there any down side of this product? Is the quality good? VCD FORMAT. Also, is there any things I should beware of when I using that product? Thx a lot!
I have had the Dazzle 80 for about a year now. It has been sitting in a box below my desk most of the time. I just started to use it the other day and it works OK i guess. I would like to hear of some of the pros and cons of this device also. I did notice a popping sound in the audio. I haven't tried it after some changes I made, maybe I will tonight. The picture was a little rough, but that might be the bundled software. Does anyone know what other software this product will work with?
Thanks,
Knight Rotax
THX Optimiser for PC monitor
By smartel in forum Newbie / General discussionsReplies: 11Last Post: 26th Mar 2011, 14:56 -
the abyss THX menu
By tcguy444 in forum Newbie / General discussionsReplies: 2Last Post: 5th Feb 2010, 10:14 -
how to insert subtitles....thx from spain
By xaviereb in forum ffmpegX general discussionReplies: 1Last Post: 22nd Nov 2008, 10:57 -
How to connect my cable box to my computer~~? THX~~
By bl3311 in forum DVB / IPTVReplies: 2Last Post: 25th Mar 2008, 19:47 -
THX HD DVD Movies????
By ofield1 in forum Newbie / General discussionsReplies: 4Last Post: 20th Feb 2008, 20:45
