I've had this burner for a while. I seem to remember store bought DVDs playing on it fine when I first bought it. I threw in a few different discs this evening to find playback slow. So I uninstalled 3.0, upgraded to 4.0. Same problem. Any suggestions?
First of all, check the mpeg filters you have installed on your system, and your graphic card drivers. Make sure they all are the latest versions. (have you installed the ivivideo.ax and iviaudio.ax software mpeg components? They slow down performance. Also check for any encoder you have added recently, check for duplicated filters, and every mpeg stuff you have installed. If your system defaults to software playing rather than hardware, it will slow down. Have you installed an ac3 software decoder lately? That may be the cause.
Antivirus suff, servers, daemons, skins, sounds and every bell and whistle added to the system all degrade system overall performance.
If you are sure your software portion is working flawlessly, check the hardware side:
Check under device manager the kind of transfer method you are using with your drive. If it says "pio mode" change it to DMA. If it says DMA, change it to PIO.
If that doesn't work, uninstall and reinstall your drive (under device maganer, not phisically)
By the way, have you upgraded your firmware? That also changes settings.
Check for loosen cables, tighten all of them. Try using your burner without another drive on the IDE chain.
If nothing works, reformat your hard drive and reinstall your OS.
OK?In this industry, Sadly, The future was yesterday.
Pioneer DVR-520h or DVR-220 or DVR-225 replacement DVD-RW drive
By psymaster in forum Latest Video NewsReplies: 1Last Post: 31st Oct 2009, 18:26 -
Pioneer DVR-560HX & random problems with CAM module + video adjust menu
By vincent_scot in forum DVD & Blu-ray RecordersReplies: 0Last Post: 27th Mar 2009, 12:03 -
Pioneer DVR 630 HS - Recording will not playback
By ktmsprocket in forum DVD & Blu-ray RecordersReplies: 3Last Post: 14th May 2008, 13:06 -
Pioneer DVR-112 seems to stop my Pioneer DVR-115 from being recognized
By Thommo1978 in forum DVD & Blu-ray WritersReplies: 9Last Post: 3rd Feb 2008, 07:02 -
Vista Media Center & DVR-MS file playback is poor
By iukini in forum Media Center PC / MediaCentersReplies: 1Last Post: 16th Dec 2007, 06:11
