    Feb 2001
    swedois
    Is it possible to do this?
    Im encoding Tarzan and i want two languages,..,.english and swedish .,.,.,
    If itīs possible to add two audiochannels, how the heck do ya do it?
    regards
    /budbrain
    May 2001
    London, UK - Bonn, Germany
    Yes it is possible. Unfortunately the only software I know that can achieve this is infamous I-Author.
    If you're interested in the process go to http://www.labdv.com/en/examples/svcd_audio.htm#step6
  3. Actually, BBMPeg will mux 2 audio channels into an SVCD with no problem, and anything should burn it just fine.
    Jun 2001
    Silver Spring, MD USA
    TMPGEnc will also multiplex multiple audio channels (onto any MPEG, actually). However, I only have an Apex on which I used these multiple audio channels, and its incredibly forgiving.
    I know this will confuse, but I'll share anyway:
    I once multiplexed four separate stereo audio tracks onto an XSVCD and my Apex played all four channels, by pressing the AUDIO button on my remote four times in sequence. The SVCD specification only supports two such channels, however. WinDVD will only recognize the first two.
    Feb 2001
    swedois
    thanx!
    i had a look at tmpgenc mpeg tools, and couldnīt find out how to merge a mpeg with two audiochannels?
    Jul 2001
    Germany
    On 2001-08-07 12:41:44, budbrain wrote:
    thanx!
    </BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
    That's an easy one: Goto Mpeg-Tools, goto Multiplex and add all the streams you want to multiplex into one file (normally one MPEG (Audio+Video) and an MPEG (only Audio)-File). Then hit run and ... wait! It will take a while, especially with one physical drive.
    Feb 2001
    swedois
    awwh! how easy,..,i didnīt look at the "multiplex" area.,.,
    thanx again..-,
