If I download a DivX movie that has been 'squashed' a bit (I think this means the aspect ratio is wrong?) as I encode it to VCD mpeg1 can this picture be sorted i.e stretched out slightly?
Stevie
Glasgow
Stevie
Glasgow -
Yes, done it many time.
TMPGEnc for instance and many other encoders have filters to resize video, not just crop it. -
budg·et n.
1) An itemized summary of estimated or intended expenditures for a given period along with proposals for financing them:
2) A systematic plan for the expenditure of a usually fixed resource, such as money or time, during a given period
3) The total sum of money allocated for a particular purpose or period of time
I hate budgets. But I do like bargains
is that all you ever think about?
no....theres also beer football and rock n' roll! -
Aguillon - I already use Tmpgenc to encode - can you tell me what to do to resize? I have at least 3 movies I want on VCD that have been squashed and need stretched out a bit.
StevieStevie
Glasgow -
What has this got to do with the questionOriginally Posted by sure_your_right
Craig -
Load the avi and wav. Load the correct VCD template to fit the source framerate.I already use Tmpgenc to encode - can you tell me what to do to resize?
Source aspect ratio 1:1(VGA
Video arrange method Custom size 352x240 (288)
Alter the second figure up or down and do a series of test encodes, preferably encoding a section that shows up correct aspect ratio (eg with something circular in it). -
Banjazzer your a star - most of this stuff went over my head before but its all coming into place now - thanks manny!
Stevie
Glasgow
Difference/Relationship among encoding, re-encoding & decoding?
By iqbal88 in forum DVD RippingReplies: 12Last Post: 19th Aug 2011, 14:46 -
How to add watermark to VCD without Re-Encoding?
By shebi in forum Authoring (VCD/SVCD)Replies: 25Last Post: 26th Apr 2009, 09:26 -
PAL VCD -> Proper NTSC DVD w/o Re-Encoding?
By SanctimoniousApe in forum Video ConversionReplies: 8Last Post: 4th Apr 2009, 17:59 -
Tool for VCD at 2500 bitrate with No Re-encoding
By whenloverageswild in forum Authoring (VCD/SVCD)Replies: 21Last Post: 6th Mar 2009, 11:34 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 16:56
