Ok I recently obtained the DVD rip of Enemy at the gates. Now the file is encoded with Divx Video and AC3 audio. I want to convert this to an XVCD but to do this I first have to convert it to a MPEG file. The problem is that I can't. TMPEnc, what I use, says it can't open it. So I open VirtualDub up and try to save the audio as a WAV and render it with the video. But the WAV file that I end up with is choppy and skips. I use direct stream copy because It gives me error messages using full processing mode. So if anyone could help me so that I can convert it to a MPEG file I'd be very much obliged.
Thanks in advance!
