I understand that Virtualdub can do this.
I cannot figure it out and can see no instructions.
Anyone?
"Today is only yesterdays tomorrow"
open your video file in virtualdub. Then select audio->wav audio. It will prompt you for the wav file. Under video, select direct stream copy. Then select file->save avi, give it a new filename and it will save a new copy of your avi file multiplexed with the video.
Hope this helps
How to properly multiplex raw mpeg-4 asp into an .avi container?
By Selur in forum Newbie / General discussionsReplies: 5Last Post: 8th Apr 2012, 10:09 -
CrossPlatform command line tool to multiplex avi files?
By Selur in forum Newbie / General discussionsReplies: 0Last Post: 23rd Mar 2012, 15:29 -
Extract Audio and video from Multiplex karaoke DVD and re author
By quebecLA in forum Video ConversionReplies: 1Last Post: 8th Jul 2011, 22:01 -
Adding audio (wav) to video (avi) (want to delay start of audio)
By Lanton in forum Newbie / General discussionsReplies: 2Last Post: 12th Apr 2010, 12:50 -
merge avi and wav
By zootedlooter in forum EditingReplies: 2Last Post: 21st Dec 2008, 13:11
