  1. Hi! Iīve been ripping some chapters from DVDīs the last month with DVD2SVCD without any problem, but since yesterday all the Audiosīs in the MPGīs are out of sync!!! No mather if I use The Cinema Craft Encoder or the TMPGEnc, they are like 4 seconds out of sync! I re-installed the program but it keeps doing the same no mather what DVD I use. The only thing that I did, that I did not do before was to use the Telecide option for 2 PAL DVDīs, but I have not use that option again and like I said I uninstalled the program and installed it again. Can anyone help me?
  2. post your log..and don't say your didn't rip it with internal routines!
  3. Here is the Log, I noticed that in the Audio Extraction saids:
    Audio1 delay: -170 ms
    Is that the problem, how can I solve it?
    - 02.07.2002 16:17:39
    - DVD to SVCD Conversion
    - DVD2SVCD ver. 1.0.9 build 2
    Initializing
    Initializing finished.
    - 02.07.2002 16:17:41
    - Free on drive D: 2881.98 mb
    - Internal rip
    Preparing vobfiles to be ripped:
    - E:\VIDEO_TS\VTS_01_1.vob
    - E:\VIDEO_TS\VTS_01_2.vob
    - E:\VIDEO_TS\VTS_01_3.vob
    - E:\VIDEO_TS\VTS_01_4.vob
    Ripping: E:\VIDEO_TS\VTS_01_1.vob
    Ripping finished. Speed: 10269
    - 02.07.2002 16:18:01
    - DVD2AVI
    Creating DVD2AVI INI file:
    - D:\Programme\DVD2SVCD\DVD2AVI\DVD2AVI.INI
    Variable settings:
    iDCT_Algorithm: 32-bit SSE MMX
    Executing DVD2AVI.
    Executing DVD2AVI. Commandline:
    "D:\Programme\DVD2SVCD\DVD2AVI\DVD2AVI.exe" -CS=2 -YR=1 -EXIT -OF=[D:\Programme\DVD2SVCD\Movie\DVD2AVI_Project_file] -IF=[D:\Programme\DVD2SVCD\Movie\VTS_01_1.vob]
    Analyzing DVD2AVI Project file
    Force Film activated!
    Framerate: 23976
    DVD2AVI processing done.
    - 02.07.2002 16:18:15
    - Free on drive D: 2873.26 mb
    - AUDIO Extraction
    Found AC3 stream id: 0x80
    Filename: D:\Programme\DVD2SVCD\Movie\Extracted_audio_1.ac3
    Audio extraction finished.
    - 02.07.2002 16:18:33
    - AUDIO conversion
    Converting Audio to MP2. Filename: D:\Programme\DVD2SVCD\Movie\Extracted_audio_1.ac3
    Executing BeSweet. Commandline:
    "D:\Programme\DVD2SVCD\BeSweet\BeSweet.exe" -core( -input "D:\Programme\DVD2SVCD\Movie\Extracted_audio_1.ac3 " -output "D:\PROGRA~1\DVD2SVCD\MOVIE\Encoded_audio_1.mp 2" -logfile "D:\PROGRA~1\DVD2SVCD\MOVIE\Encoded_audio_1.lo g" ) -azid( -L -3db -c normal -g max ) -ota( -d -170 ) -ssrc( --rate 44100 ) -2lame( -e -b 128 -m s )
    Audio conversion of D:\Programme\DVD2SVCD\Movie\Extracted_audio_1.ac3 finished.
    Audio conversion finished.
    - 02.07.2002 16:19:37
    - Video Encoding using TMPGEnc
    - Encoding D:\Programme\DVD2SVCD\Movie\AviSynth_Script_file.a vs
    StreamSectors: 771537788
    AudioSectors: 2972396
    VideoPAPO: 11905488
    ScanOffsetBytes: 3846
    SeqAligningBytes: 244416
    DVDBytes: 0
    VideoEndHeader: 4
    SubtitleSectors: 0
    EmptySectors: 238.00
    PictureSectors: 0.00
    PureMPEGStream: 756411638.70
    Seconds: 183.22
    CalcMPEGStream: 756411638.70
    Frames: 4273
    CDSize: 740.00
    Cut point 736.00
    Aspect Ratio: 16:9 (borders added, encoded as 4:3)
    ---AVS Begin---
    LoadPlugin("D:\PROGRA~1\DVD2SVCD\SIMPLE~1\SIMPLE~1 .DLL")
    LoadPlugin("D:\PROGRA~1\DVD2SVCD\MPEG2DEC\MPEG2DEC .DLL")
    mpeg2source("D:\PROGRA~1\DVD2SVCD\MOVIE\DVD2AV~1.D 2V")
    SimpleResize(480,360)
    AddBorders(0,60,0,60)
    ----AVS End----
    Executing TMPGEnc. Commandline:
    "D:\Programme\dvdgenie\TMPGEnc Plus (Registered)\TMPGEnc Plus-2.53.35.130\TMPGEnc.exe" "D:\Programme\dvdgenie\TMPGEnc Plus (Registered)\TMPGEnc_Project_file.tpr" /Encode /Close
    Video Encoding finished.
    - 02.07.2002 16:58:18
    - Free on drive D: 2753.88 mb
    - Converting Pictures from ES to PS
    Saving bbMPEG settings: D:\Programme\DVD2SVCD\bbMPEG\default.ini
    - 02.07.2002 16:58:20
    - Free on drive D: 2753.87 mb
    - 02.07.2002 16:58:22
    - Multiplexing and cutting
    Offset in Seconds: 2
    Executing bbMPEG.
    Variable Settings:
    Movie offset: 2 seconds
    Cut point: 736 mb
    Executing RunbbMPEG. Commandline:
    "D:\Programme\DVD2SVCD\bbMPEG\RunbbMPEG.exe" "D:\Programme\DVD2SVCD\Movie\bbMPEG_Muxed_File.mpg "
    Multiplexing and cutting finished.
    CD-Image creation finished.
    - 02.07.2002 16:58:55
    - Free on drive D: 2703.32 mb
    - SVCD Creation finished!
  4. I found out whats happening but I donīt know why?
    After the encoding, the chapter that I capture begins like 2 seconds later than where it begins in the DVD, but the sound stays the same so the final mpg is out of synch, can anyone help me?
  5. deselect any zero length chapters...1.0.9 build 3 does that automatically for you. If it's still you causing problems...look in the advanced reference for bbmpeg and change your startup delays.
