What is the best way to prepare a flash file (.swf) to be burned to a VCD for optimal quality?
hi ..
maybe i can help u....
i believe u need to set res to the same as your vcd,and u need to export the swf to avi then use your usual program to convert it to vcd
i hope it helps u -
i see. that is my problem. my original flash movie was not the correct resolution. thanks for the input.
dont u have the "*.fla"?the only way to resize the swf...
but...u can resize the movie avi..in any software, vdub,vs6, msp, tempg..etc..
Help me (How to flash pictures)
By freddiejos in forum EditingReplies: 4Last Post: 3rd Aug 2011, 12:02 -
Using flash to export
By bearsbowl37 in forum EditingReplies: 0Last Post: 15th Nov 2008, 14:10 -
nothing will convert to flash
By Cadobee in forum ffmpegX general discussionReplies: 15Last Post: 26th Oct 2007, 10:40 -
Flash player 9
By ray316 in forum Software PlayingReplies: 5Last Post: 2nd Oct 2007, 18:28
