    Mar 2001
    Virginia Beach, VA
    while doing a rip conversion of "V" the mini-series..at the end of my first disk... the sound cuts out for the last 3 seconds or so... thats ok... I always overlap a bit..
    How can I cut or delete just those last couple seconds of my mpg without having TMPGenc do a cut/join?
    I tried cutting it out till that spot, and it just made it worse...
    What program(s) can I use to just delete the last couple of seconds... without a ton of processing or time... I know the time frame/frame number to cut from to the end...
    thanks.
    Mike
  2. Define 'a ton of processing' time I would use bbMPEG. You'd have to:
    1) Load MPEG in bbMPEG
    2) De-mux MPEG (ie. spilt into MPV and MPA files
    3) Choose start/stop point for new MPEG file, and mux it
    I have a Tbird 1.2Ghz and to do this for a 730MB MPEG2 file takes ~8min for start to finish. TMPGenc will do the job in one step, but I think bbMPEG is faster at cutting.
