I have a file that, after converting with tmpge, using the wizard and setting for NTSC (mpeg1, 352x240, 29.97fps) makes the file to 757 megs, too big for the cd's I have (stupid question here...) do they make a 800 meg cd? if not what settings would I use to make the file smaller to fit on the 700 meg cd if I redo the conversion in tmpge, or would it be smarter to use a video editing program to cut it in half and write it to 2 cds? THANK YOU!!![]()
A regular 80min/700MB CDR can store up to 800MB or 80mins of VCD. This is due to the VCD not having error checking that frees up space. So you should be ok to burn your 757MB VCD. I just burnt 792MB CVD on a CDR today.
Joshua. -
http://webs.ono.com/usr016/de_xt/
or use "mode2 cd maker" for NON VCD/SVCD files. you could put a 800mb divx avi on a 80min cd -
Originally Posted by Lord Gaiyan
BTW, this was a great question.
I need to cut a MOV file
By a11111 in forum EditingReplies: 10Last Post: 30th May 2016, 15:18 -
vlc - where does it write it's log file?
By minidv2dvd in forum ComputerReplies: 2Last Post: 31st Jul 2009, 10:48 -
Can you cut this file losslessly?
By tokintmash in forum EditingReplies: 17Last Post: 10th Mar 2009, 01:57 -
cut vob file
By xxxjojoxxx in forum EditingReplies: 8Last Post: 25th Dec 2008, 09:06 -
how to cut a wmv file
By stranzer in forum Video ConversionReplies: 5Last Post: 22nd Jun 2008, 11:26
