    Sep 2001
    Canada
    Everytime I try to open an MPEG2 file (from an SVCD) using TMPGENC I get the following error:
    File "H:\MPEG2\AVSEQ01.MPG" can not open, or unsupported.
    Tried this from many SVCDs (which do work by the way) with no success. Help ?
  2. you must to install the mpg2 codec to open SVCD
    look the forum. look in Tools section for download.
    Sep 2001
    Canada
    Did that, no luck.
    Well not with the one in the Tools section anyways.
    I remember I used to have an MPEG2 codec before that was just a simple EXE with "InstalL" & "Uninstall" it was freeware, anyone have that one somewhere?
  4. Yes, that's the good one, I have it at home. Email me at studio@energy80s.com and I'll send it to you.
  5. Try the mpg2 codec from the "Nimo Codec Pack" in tools
  6. Free Flying Soul liquid217's Avatar
    Feb 2002
    you need the tmpgenc plugin to open mpg2
    http://www.vcdhelp.com/download/m2v_vfp-0.4.6.zip
  7. Try to use Vidomi... It's a great prog !
    You can find it on www.vidomi.com ............
