Hi. I just tried converting my first DV-AVI (type 1) file to an SVCD MPEG-2 file using TMPGEnc. I got no error messages and burned to CDRW with Nero. The video looks perfect on my DVD player but the sound is messed up. The only way I can describe it is it's "demonic"-sounding. It's like playing an LP on the wrong speed except it's not slow and there are no sync problems. The frequencies are just too low so my voice sounds like some sort of beast and my wife's voice sounds more like mine. Any ideas?
Also, since I'm burning with Nero anyway, couldn't I just have it encode the avi file when I go to write the disc? Will this work? What about quality compared with TMPEG?
Thanks.
what you want to do is get a prog named avi2vcd and use a tool it has to decomperss the avi file (the sound really) and then you encode using that.
Nero 7 audio sync problems
By CRJ705driver in forum Authoring (DVD)Replies: 5Last Post: 26th Sep 2010, 03:25 -
Problems with TMPGENC 4.0 XPRESS + TMPGENC DVDAUTHOR 3.0 :( help
By neurosys in forum Authoring (DVD)Replies: 3Last Post: 10th Aug 2008, 19:37 -
Nero Vision5 and problems with avchd
By gekko_video in forum Authoring (Blu-ray)Replies: 1Last Post: 14th Apr 2008, 05:28 -
burning problems with nero 6
By jjob222 in forum Newbie / General discussionsReplies: 6Last Post: 16th Jun 2007, 16:36 -
NERO 7 Problems
By theegokiller in forum Newbie / General discussionsReplies: 2Last Post: 10th Jun 2007, 21:21
