Anyone here knows of any program that will rip the Chinese movie that has a English subtitle when played on DVD Player, but cannot rip english subtitle. It only rip chinese sub, but i need the english one, 'cause i can't read chinese.
I also have another movie that has multiple languages selection on the main menu. when I play it on dvd player, it play any of the language that I select, but when I tried to rip it in SmartRipper, it doesn't have the language that I want, only in Chinese...Any idea on this
Thank you very much...for your help
Did you check the boxes on the setting of SmartRipper to select the program to rip the subtitles you want ?
no english sub on the boxes, only chinese sub
how do I get the english sub to appear on those boxes?
Even the DVD2SVCD doesn't show the english sub.
Thanks for helping -
What about CladDVD ? Have you tried this program to see whether it would rip the subtitles you want ?
Hi !
Why don't you use DVDx ??? It's much esier..... Just mark the subtitle you want and press go.....
I have a P4 1,7 Ghz and after 2 hours i have a perfect mpg-file..... -
Does DVDx copy the content of the DVD movie to the HD or just starts encoding straight from the DVD-ROM ?
2 hours and the encoding finishes??? Thats fast !
It took me 4 hours and 50 minutes to encode Pearl Habour DVD (2 disc) to VCD. But if I encode DivX to VCD, all it takes is 1 hour and 26 minutes. -
You can choose.... You can change the parameters in the program , so it copies the movie to the harddisk first and encode from there. I think your cd-rom motor would appreciate that solution.....
. I've never had aby problems with DVDx... It works just GREAT !!!
mp4box and non-English subtitle
By ngngokkiu in forum SubtitleReplies: 1Last Post: 10th Mar 2012, 05:37 -
DVD plays, won't rip (now rips with CDRoller, won't import to TMPGEnc)
By koberulz in forum DVD RippingReplies: 14Last Post: 4th Dec 2011, 10:42 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 21:21 -
Adding English subtitle to french film?
By viruss3 in forum Authoring (DVD)Replies: 3Last Post: 23rd Apr 2008, 15:03 -
converting a subtitle to english?
By php111 in forum Newbie / General discussionsReplies: 10Last Post: 14th Aug 2007, 08:20
