  1. I found a simple Visual Basic tool on the web that creates batch lists for TMPEG:
    https://www.innsys.com.au/doylie/cat_Development/TMPEG_Batcher/TMPEG_List.htm
    Those who are familiar with it, is there a better one, or are you setisfied with this one? I am thinking of writing my own that will include most of the options. You think it's a good idea?
    May 2002
    Rainy City, England
    What is wrong with TMPGEnc's own batch list option?
  3. Well, for one thing, you have to click every file and load config for it. Tmpeg resets resolution to the one of the video and not the currenly loaded template. My hand gets numb sometimes loading files.
    May 2002
    Rainy City, England
    If you use the standard (S)VCD templates, the resolution is locked. If you are using a modified template, you can lock the resolution by editing the template in a text editor.
  5. That simple?
    May 2002
    Rainy City, England
    Yes. 8) Just a question of altering "ReadOnly = False" to "ReadOnly = True" in the right places.
