Hi All,
I ripped the movie Pearl using cladDvd, and encoded to MPEG2 using TMPGENC+.
I burned the MPEG2 using Ulead's Movie Factory w/o any problems.
BUT, when I play the DVD in my Pioneer, if there's a lot of movement in the scene, the picture is very "jumpy". When I play the MPEG2 on my PC, it has the same problem. Other scenes with less movement are fine, and the picture is great!
Do I need to change the settings in Tmpgenc+ to correct this problem? I used the wizard, and the NTSC - DVD template w/o making any changes other than the field order, which I switched to B top order first.
System: Pent2Ghz, 512M Ram, 120Gig HD, Windows XP, Ulead MovieFactory, HPdvd200i. DVD was burned to an HP, DVD+RW Disc at max speed.
Nutty1
Can anyone offer any suggestions/help with this one please?
Thanks!Nutty1 -
i know what your problem is u need a better pc..yours is just a lil bit out dated
lolol...jus kidding (of course)
Jumpy playback on XP media player
By WBFAir in forum Software PlayingReplies: 7Last Post: 23rd May 2008, 09:26 -
"Sliced" playback during pans and action scenes.
By GMaq in forum Software PlayingReplies: 9Last Post: 1st Nov 2007, 09:07 -
Jumpy playback, dropped frames during capture, CPU pegged to 100%
By tylerz in forum Newbie / General discussionsReplies: 7Last Post: 24th Jul 2007, 17:09 -
Jumpy DVD ?
By Dash1 in forum Newbie / General discussionsReplies: 7Last Post: 2nd Jun 2007, 14:53 -
Vista Basic - Hard drive is always busy
By edong in forum ComputerReplies: 39Last Post: 21st May 2007, 09:28
