I noticed a captured video of a family band had a somewhat lower sound level than the VHS tape it was taken from.
Can TMPGenc boost the sound any, during encoding for other things that I want to do?
Don't know if TMPGEnc can do it, but you can use toolame (or BeSweet which is a GUI for toolame and other command line audio tools) to boost the gain when converting to MP2. You can also use BeSweet to compress the dynamic range which can have the effect of giving the audio more punch!
My personal preference is to use an audio editor directly on an uncompressed wav file to normalize and boost the gain. Since you're dealing with a captured file, you should be able to demux the captured avi and save to a WAV file (via direct stream copy) in V-dub and use the audio editor on that. Once you're done, use BeSweet GUI to encode to MP2 for muxing with the video file TMPGEnc makes.hitch -
Click Setting>Audio check the Use Audio edit button and select "edit", you can then change the volume of the audio...
Yes, it can. Select the Settings button. Then select the Audio tab > Setting > Normalize > and then enter a percentage. TMPGEnc will scan the audio, and then choose the scaling factor for you. Once you do this, I think you can play the audio to get an idea of the sound level before you encode.Originally Posted by joeAgain------
You can also specify an alternative audio encoder under Options > Environmental Setting > External Tools... TooLame is one such encoder, but I prefer SCMPX (http://www.hitsquad.com/smm/programs/SCMPX/). I also use SSRC (http://shibatch.sourceforge.net/) as a sample rate converter.
For MPG's you've already encoded, you can re-encode the audio and MUX it back into the video. The MUX/DEMUX options are found under File > MPEG Tools.
How to increase Video Sound Levels on AVI. Files or Mpeg
By c_a_konopka in forum EditingReplies: 14Last Post: 27th Jun 2012, 21:48 -
Sound Levels when playing Movies
By zenzen1 in forum AudioReplies: 3Last Post: 4th Feb 2010, 23:40 -
HELP! When i press encode it asks where is process.app?
By kanis2306 in forum ffmpegX general discussionReplies: 6Last Post: 11th May 2009, 15:03 -
Sound Levels
By wolfnature in forum Newbie / General discussionsReplies: 4Last Post: 19th Feb 2009, 14:02 -
AKAI LCT2721AD Cant program the remote and very poor sound levels.
By ibex333 in forum DVB / IPTVReplies: 2Last Post: 14th Apr 2008, 12:01
